VictoriaGuy
Well-Known Member
Hey KGMMan! The hole in the of the chassis is only wide enough to accommodate one side of the transformer.
You can see the photos of the fit here..
http://thediyexperiment.blogspot.com/2010/11/getting-started.html
The side with the wires would not fit through that hole? If the 'fat' side with the bell cover will fit through, I'm surprised that the end with no cover and the wires will not clear...but who knows, with these 'kits'. They are a long,long way from Heathkits of the olden times....
Sometimes it takes a bit of maneuvering and even widening the opening a small (1/8 inch) amount to get the wires to pass through.....
(You would probably have to undo the 4 bolts and reverse direction of the bolts.....)
