I couldn't find a good reference for the trouble I had with this 570 turntable. (AI was some help). Maybe there's a better one somewhere but this post will help those that share the same brain I have. (I feel for you).
The turntable was in pieces when purchased. After putting things back in order, the adjustments were all off.
The triangle foam bumper was missing. Pioneer calls it a cushion (PES-035) which has to be made locally.
Testing the operation. The Led-in was way off and the auto return did not work at all.
There are three versions of the Auto Return Assembly. The electrical adjustments are the same even though the boards are different.
Connection for the scope test pin (CL), there wasn't any trace with the tonearm in the on position.
There was 14.5vDC from the sensor pins GR (Gray) and BL (Blue) with the tone arm at the 60mm mark from the center plater point (album hole). There's a special Pioneer tool, but I made one from a wood shim and used tape to secure the position.
With the tone arm in the on position, there should be a trace. ("On" position, is any place except the rest).
When moving the tonearm near the 60mm lead out you should see a voltage change down, from 14v to below 1v.
The easiest way to set the voltage is to set the tonearm at the 60mm position and adjust the mechanical to get the lowest voltage reading and then adjust the VR101 to get the 2.5vdc. It's fiddly.
The scope trace should change from a sign with a knee to a sign when approaching the 60mm position. The manual shows a square wave. Maybe on the Version 1 board? I couldn't get the square wave at all.
I couldn't set the voltage at all until I replaced the phototransistor and IR LED.
There was no trace whatsoever until I replaced the two IC's.
The clearance for the sensor and target plate is critical.
If all you get is the 14.5v when moving the tonearm through the travel, the sensor has a component out.
If there's is no trace on the scope, the ICs are toast.
VR101 on my board was 10k ohms which made it really sensitive.
There is a little bit of modification needed to make the sensor components fit.
Follow the manual for the procedure. The manual has you pull the plater motor connection plugs, so the motor doesn't spin when moving the tonearm.
I spent a ton of retirement time tinkering on this so you don't have to.
IC (IC Audio Amp) IRS2092STRPBF. Two required.
Phototransistor BPW85. One required
IR LED transmitter INL-3AHIR15. One required.
