mlannoo
I picked up a 2220 on Craigslist a while back and began my first recap job. The unit was working except the FM part (stations would not come in, volume was very low and signal strength was poor).
I purchased a recap kit online (caps, trim pots, bulbs, key transistors etc.) and after overhauling the P500 pre board, P700 main board, P800 power board, P900 phono board and the large cap can filter caps I find the FM problem persists - still the volume on the FM is very quiet compared to the AM, Phono and Aux channels. The signal strength meter is all the way left indicating poor signal also.
I took it to a local tech who opened it up and had a quick look and he suggested I try recapping the P200 FM IF board and the P300 MPX stereo board. So I gave that a try and also replaced all of the transistors on both those boards and once again, the problem persists.
Any ideas on where to look next? This is the "shotgun" approach I know but it's a fun learning experience and hopefully when I get this figured out It will help me (and others on here) down the road.
