Jinxt
Just returned home from picking this receiver up on craigslist. Cleaned the wood case, sprayed the knobs down with deoxit and fumbled with them for around 20 minutes to try to get them clean. Hooked it up to my speakers and turntable, put on some Smashing Pumpkins and I hear the most glorious tones start emanating from... The left speaker. Checked the fuses, fumbled with the speaker select a bit since that has some choppiness, changed from bank A to bank B, swapped speaker wires, swapped RCAs, tried aux, tried FM. No go. Can't get the right channel to produce any sound. Futzing with the speaker select dial I CAN get both channels to come in with headphones, but not consistently and the slightest micro-movement of the dial cuts it back to hard left.
The protection light does come on intermittently depending on which buttons I have depressed (Loudness, Reverse, etc).
Does anyone know of any techs in the Hampton Roads area of Virginia (aka, Tidewater, preferably the Peninsula, Between Hampton and Williamsburg)?
The sound I'm getting out of the left speaker is suited exactly to my tastes and matching up perfectly with the speakers I currently have hooked up (Kenwood LS-909). Moreso than the Sony STR-7045 that at this point I have to assume needs a re-cap and tune-up now that I've used something else.
Any seemingly easy fixes I might be overlooking? I have the service manual and a soldering iron (though my soldering skills are almost totally nonexistent).
