Troubleshooting CD Players
Hello, I bought a Sony X333-ES with faulty tray, which I managed to solve (belt issue). Then a second problem became apparent: the laser lightens and tries to focus, but the CD never spins. Any advice from your experience?
If it's the spindle motor you would hear a sizzling sound. You can give the motor a little spin, clockwise, and if it continues to spin you have a bad motor. A bad spindle motor in a Sony home CD player is rare. In 40 years of servicing them I think I've replace 2 motors.
Dr, is there possibly a laser power adjustment on the board as a last ditch effort? Couldn't hurt if the laser is suspect.
I just checked: inserted a CD, I heard the laser trying to focus and then nothing. After that I tried to spin manually the CD and it spins freely on both clock and anti clockwise.
Bad laser. It isn't achieving focus lock because the laser power is too low.
Did you clean the laser lens? I watch (too many) Spare Time Repair videos on YouTube, and the guy cleans the lens on almost every CD player that he looks at. I bought one of the swing arm Magnavoxes and it didn't read anything. Popped it open, saw the lens was covered with some goop, cleaned it, and it works fine.
I clean the lens on every CD player with read problems and it rarely fixes it.
Yes, I cleaned the lens, but it didn't correct the issue.
Too bad - coming from camera repairs, I was dubious of cleaning laser lenses - they are coated plastic and I wasn't sure what would be safe to use on them. But Spare Time's sometimes vigorous cleaning suggested to me that I was over cautious. And in the case of the Magnavox, it worked immediately. So I thought it worth asking..
  • Like
Reactions: j!m
Hello. I have a Nakamichi CDPlayer2 that has been in storage for a long time; I’m not sure if it was working when it was put away. The issue is that it reads the TOC (Table of Contents) quickly, but when I press play, it struggles to locate the first track. When it does manage to find it, there is background noise, skipping, or it gets stuck in a loop. It also fails to locate tracks when using the skip function. Interestingly, on the rare occasions when it does work, the RF signal amplitude is over 1 Vpp and appears very clear. I have already lubricated both motors, the sled moves smoothly, and I don’t see any broken gears. Do you have any suggestions? Thank you very much.
Carefully clean the lens is where I'd start under the symptoms you're describing.
Does it sometimes play/sometimes not the SAME disc, or is it disc dependent on play/no-play?
Cleaning the lens is the first thing I do; there’s no difference between CDs it’s the same with all of them. What I hadn’t noticed, however, is that the rubber component holding the lens and the focus and tracking coils has degraded; it’s resting against the optical assembly support instead of floating. I believe this could explain the issue, though I don’t see a simple solution for it.
From the rf waveform I would say the laser is ok. Try applying a couple drops of light machine oil to the top bearing of the disc motor.
Alright, Doctor—what’s your take on the lens resting directly on the base of the pickup assembly instead of "floating"? It looks like the rubber has worn out or degraded; is there a fix for this?
