Troubleshooting Kenwood C2 and M2
M.O. Deloofs
Fellow Kenwood aficionados,
I have read several threads on this topic however I am relatively new to stereo troubleshooting and the volume of information is kind of overwhelming and I wasn't necessarily finding my exact scenario in these older threads.
I recently acquired a C2 preamp and M2 power amp. I cleaned up the exterior of the units and plugged them into some small speakers to test for functionality. All buttons and switches seem to work however I barely got any sound out of my test speakers even with all volume controls turned all the way up. The balance pot is scratchy and poppy when I turn it. The power meters on the M2 did not register at all though the displays do light up.
I am aware of the balance pot issues with the C2. I am planning to test the M2 with the preamp out on my SS-97 surround processor. After that I will take them apart and Deoxit all the pots and switches that I can reach. I am also aware of DRM Audio and have read through their catalog and identified the balance pot kit.
Can anyone recommend anything else I should check?
maybe post a pic of your C2. these are pretty simple. tape set to source, mute off (green output led lit), ... here is my dusty c2.
Here's the stack with M2 and SS-79 surround processor. I had the tape set to source and output on with green light on.
can you bypass the SS-79 to remove that from the issue? did you narrow the issue down to the preamp? i've used RCA's to 1/8" plug cable and a portable music source (cell phone, ipod, laptop, ...) to control the amp. turn down the gain pots on the M2 before you press play.
that M2 is nice. I currently swapped one in my main system.
The SS-79 isn't connected to anything, it's just sitting between them. I have not narrowed the problem to the C2 but I will try to feed the M2 from the preamp out of my SS-97 surround processor, hopefully this weekend. If the M2 works with SS-97 preamp I'll know I've got an issue with the C2.
Okay I ran the SS-79 direct into the M2 with the preamp out and it got good volume so that verifies that the M2 is in working condition. The SS-79 isn't a standalone amplifier and only has surround modes so I can't really test for the sound quality of the M2 but I can tell it's working.
That indicates that the problem is with the C2.
