Hi,
A newbie from Finland salutes you all with golden ear!
I bought years ago a C-70 that had "minor flaws". In practice this means the unit makes a buzzing sound after powering on, not to output but physically audible buzz. The sound fades after few minutes.
Before yesterday I have not had access to proper oscilloscope but now I have tools for troubleshooting and I am trying to cope with the learning
According to C-70 Service Manual the power unit gives following DC voltages:
+ 33 V
- 33 V
+16 V
-16 V
The +/- 33 VDC are stable. There are problems with both the +16V and the supposedly +24 VDC to operate the relays. Both have a 100 Hz anomaly that explains why the buzzing sound occurs after powering on: relay RY101 vibrates making a 200 Hz sound.
This is what the 24 VDC looks like when measured from the opering voltage pin of RY101:
The 16 VDC has also problems. This is measured from the yellow wire soldered close to RY101 with text MUTE +16 SD1 on the component side of the PCB. The GND of the probe has been connected to the outer ring of RCA connector connected to the same PCB.
I cannot figure out where the +/- 16 VDC and 24 VDC are generated in the power supply. Any hints how to proceed?
The unit has been serviced by someone at some stage. At least capacitors C596 and C597 have been changed to Rubycon 10 000 uF 50V 85 Celsius capacitors and some other capacitors too. I have visually inspected the soldering of all components that look like they have been changed. I have not found any solder bridges or cold joints that would explain anything.
+ 33 V
- 33 V
+16 V
-16 V
