Trusted Brands for a Phantom Power supply
Michael. T
I've got a condenser mic and I've been using it without a power supply for a while but it's a bit annoying to use. The audio I get from it is very noisy and with noise canceling on I have to be right up on the mic to get decent volume out of it. I started to look around for a power supply hoping it would help and I've seen a few Brands like Neewer and Behringer but I'm not sure if their products are any good
I'm surprised you get anything out of the mic, my condenser mics do nothing without power. I get phantom power from my devices....pa head, porta studio, tube pre-amp. I imagine any of the ones you're looking at will be fine. It's just 48 volts DC.
You need a mic pre that has phantom power. Most all do. You can spend as little or as much as you want.
If you're going into a computer you'll need an interface. These typically have a mic pre built in along with phantom power. Also can be had cheap. Behringer, Presonus, ART, are some that make inexpensive units that will work.
I'm surprised you get anything out of the mic...
Me too. How does a phantom powered mic work at all without phantom power? :dunno:
There's a chance that the condenser mic in question is an electret condenser designed to work from the 5V of a USB port, but if that's the case there's no way it will work from phantom power.
A third alternative is that it's a "proper" balanced electret condenser that will work from phantom power or an internal battery. If that's the case, swapping from battery to phantom power won't alter the gain or S/N ratio.
Perhaps the OP should tell us what the mic is.
