Couple of updates:
I had asked here, for a solution to the slipping platter shaft on the coupler item. I wound up using a middle ground solution. I used a high quality drill to drill a hole into the platter shaft. I drilled it about 1/2 through the shaft, and it was big enough for the set screw of the coupler to go into. I feared drilling completely through the shaft, as there might not have been enough metal left for strength. I bought a longer set screw from the hardware store, and screwed that snugly into the coupler/platter shaft.
I have not had any more slipping or tightening duties, even without the locktite.
On the vaccum/catch tank item-I did buy a little shop vac, and attached it's hose to the cleaning wand, as a test. It works fine, but honestly, I did not take the time to modify the hose to fit the wand coupling-I just used electrical tape. As the hose is a tad smaller than the wand coupling, the wand does not move down without some help from me-the lip of the hose is in the way. Also, I did not wire the vaccum into the on board switch, so I have to use the switch on the shop vac.
I know I could solve the wand/hose item, and I could wire the vac into the on board switch, but I think I will just return things as they were, and drain the dirty/spent liquid every 3-4 albums.
Now I have a convenient little shop vac I can keep around the work bench-very handy.
After all is said and done, the whole project cost me close to $300, and took many hours of planning and maybe about 12 hours of work. I could have just gone out and bought a unit for about double that, but I like mine better, and I have the satisfaction of the build-worth a good bit, actually, but impossible to quantify :scratch2:
The biggest thing I learned or should I say, came to believe, is that these things are well worth the cost and/or trouble, for record lovers like me. I started out nearly outraged at their cost (even those hovering around $600-one can easily spend a lot more....), but I see them now as a good value, especially if one buys thrift store/well used stuff, like myself. They always play a bit better, sometimes a lot better after cleaning, and I am relieved from the guilt of dragging my modest stylus(s) (styili?) through the muck of a grungy disk.
Call me a convert :thmbsp:
