allanmatters
Once again I am back with fiddling with my Pioneer HPM ribbon tweeters. I bought these speaker in 2014, of course the tweeters were not working back then ( I know this cause I disconnected all the other speakers in the box and listened for the 16kHz frequency, but they never produced the magic sound I wanted.
So I took them apart and tried tightening the terminals at the end and reassembled it back . No luck.
Then i tried something different. I took some speaker wires (thin ones small gauge) and I connected it inside the thin film of the ribbon tweeter film ( I put the wires on the sides inside on the front of the film where the original terminals run through in parallel. Reassembled it and voila ! She played finally. But it did not stay for long. It keeps going and coming ( like its telling me the connection needs to be as accurate as possible).
I was a fool to think that soldering the wires to the thin film would work but that just burn / eats up the film.(its in good shape though. 1% damage only done by the soldering trial and error process)
But its still works sometimes ,comes and goes. So I did not connect it back to the speaker box.
The other tweeter was more tough to fix. It never really fired up at all when i tried the same trick.
My ribbon tweeter wires which comes from the crossover, works (both of them work) I checked it by swapping the ribbon tweeters when i managed to almost fix one.
I ended up putting another ribbon tweeter which I took out from a Pioneer cs-c11. It had the transformer attached to it already so i took a direct connection from the speaker terminals behind the speaker box (not from the crossover board) and hooked them up (these ribbon tweeters also have their own independent magnet, a big one too). They seem louder than the original ones which came with the speakers. I have heard that the ribbon tweeters on the Pioneer hpm-700's can give up to or more than 16kHz frequency.
However i find that less since the tweeter can dominate it in terms of loudness.
So i installed some ribbon tweeters I found from a Pioneer cs-c11 . Its installed from inside the HPM box, not from outside like the originals were ( doesn't look very pretty but it does the job ( clear sound and freq from these ribbon tweeter as a replacement)
My questions are -
Does any one know any other way I can get my HPM ribbon tweeters to work. Is it worth the shot? I mean I like my speakers to look and have all its original parts ( in this case I am happy but the substitute part ( ribbon tweeter) does not really match in terms of fitting. More importantly how can I get them to work ? the best way to get contact with the + and - inside the thin film so it can work
Are the HPM-700 ribbon tweeters good at 16kHz ? I can hear it since I am still young and my ears are good. But it lacks loudness from a distance. I mean can we really hear it from a distance when all other speakers are working ?
Will attaching a magnet behind the original HPM-700 ribbon tweeters increase the frequency ?
I have attached some images on my work just for your reference
My questions are -
