Hey all,
I'm trying to identify the cartridge on my TT. I dug my dad's old table out of storage a couple months ago, and I want to replace the needle, as I'm not sure how old it is or what kind of shape its in. I've attached a couple photos so you can see the cartridge.
After a bit of research, I found there seem to be 3 versions of the 773 cartridge: moving magnet (which was aparently red or black), moving coil (which is silver, like mine, and is why I think that's what I have), or High output moving coil (which was gold). I believe I have correctly identified mine as a Mission 773 MC silver cartridge. However, the only needle I've been able to find that's a close match is here: http://www.styli.co.nz/mission.html
(also, in a manual I found online here: http://www.vinylengine.com/library/mission/773.shtml they refer to them as LC, HC, or SM. I'm not sure what those mean, but I think mine would be the HC)
Unfortunately (?), the only stylus I found seems to be for the 773 MM. So the difference here, if I understand correctly is that one is "moving coil" and one is "moving magnet", but i don't know if that affects the needle I should get. Are the styluses interchangeable? I'm still relatively new to this stuff, so I don't know if I can just get the MM needle or not. If I can't use the stylus I linked to above, then does anyone know where I can get the right stylus?
Thanks
Thanks
