TU 717 Buzzing.
No mono source in either software or hardware. I'll try an AM station. I did roll the balance left & right and the right channel on both A/B is super low and there's static. What are you suggesting?And is this just a coincidence? A 30 + year amp just gonna have issues.
For what it's worth, the TU-717 does have an FM mono mode (FM Auto allows stereo when there's a signal available; FM Mono forces mono). You might tune in a stereo station, then switch to mono for testing.
I'll give it a try when I get home.
On the back side near the pre-out - amp in jacks there is a switch. I would wiggle it, these connected/disconnected switches are notorious for causing this very issue.
Holy crap!! That was it.
I believe the buzzing was because I had a rheostat lamp plugged into the same outlet. Not a ground loop issue. Man thanks for such a simple fix. Now why is that integrated/ pre-out switch doing that?? Just a bad design.
