Hi,
I'm doing a major overhaul on a dirty, abused TU-9900 I found. All the main boards are going to need cleaning. This will require major parts removal. The unit needs new resistors pretty much throughout because so many of the stock carbpn comps measure well out of tolerance. What boards can take metal film resistors (in place of carbon comps) and polyester caps (in place of the larger ceramics), and what boards need to remain as stock due to inductance issues? Specifically I'm asking about the AM IF Board (F-2539), the FM IF Board (F-2524), the MPX amp (small board on the bottom side), and the Discriminator board (F-2525) These are the ones I need to know about.
I'm pretty sure I can use metal films throughout the MPX/Audio board (F-2526) unless someone says different and I rebuilt the power supply using one value higher than stock wattage rated carbon films.
