teuchter85
I'm in the US and recently acquired a Luxman MQ-3600 Tube Power Amplifier. It was originally a Swiss unit and as such is rated for a 220V 50-60Hz power input. Obviously, I need a step-up transformer, but most of the ones I have looked at state that they are 110/120V to 220/240V which would indicate that they are simple voltage doublers. The voltage in my house is fairly consistently around 119/120V, which would mean that I would get around 240V out of the step-up. My concern is that as all the voltage rails inside the power amp are unregulated I would get ~9% higher voltage rails by running a 220V rated unit at 240V. I'm sure that some degree of headroom is designed in, but having, for example, a nominal 495V rail running at 540V worries me. Any thoughts/suggestions?
