This is a continuation of the thread I started with a question about using different output tubes to replace ELL80. Out of all possible contenders I only have (plenty of) 6BQ5 tubes, so I decided to give it a try.
Amp was quickly knocked together using Allen organ PS chassis with no cosmetic goals in mind.
I copied driver / inverter stage from 29T schematic, modified PS and bias circuits, added individual bias adjustment, screen resistors, and DC elevated heater windings (there's one individual per channel).
I get around 315v B+ rail. Output tubes are biased at 22mA of cathode current and amp produces around 13wpc into 8ohm with both channels driven. With the original NFB network values, I get 14dB of applied feedback. Frequency response looks decent at 1w, square waves look good. The amp seems to be very stable and I couldn't find a load combination to upset it. I haven't tried to increase the feedback level yet.
Input sensitivity is around 390mv.
All looks promising except one issue. At full power and even significantly below it, wheels are falling off the wagon below the 60Hz mark. At first, I thought that it was OT saturation but after seeing similar results at lower power levels I scoped inverter output and it shows a similar scope pattern that I see on output terminals.
I took series of scope screenshots, including inverter outputs.
Does it appear that the driver stage runs out of steam? The famed "noose"?
Here is 1KHz square:
8KHz:
Here is what's happening across dummy loads:
Here is the inverter output simultaneously:
And here is the schematic:
8KHz:
