triode17
Keep in mind the fact that you can't properly drive a SS amp. with a tube pre. The tube pre. outputs are too high an impedance and you will lose Bass. BUT, if you added a tube buffer in between, then all is fine. I say buy a buffer first, then slowly convert to all tubes. I built an Aikido tube buffer, cost me about $75 and it works very well. Distortion down below 0.06%! I think a kit is available, if you can solder.
