JCLAY85
Hi All,
I've been working hard to try and get my Drip Opto 7 (stereo LA2A clone) up and running. I posted yesterday about the power issue (which I got resolved). Its working for the most part, but I have 4 issues that I would surely appreciate any help with and thought I'd see if anyone could point me in the right direction!
1. Hum
Sounds maybe like ground loop hum? Its lower in pitch, like if you grab a guitar cable that's coming from an amp. I hear it even when the gain is all the way down. The volume of the hum doesn't change. Powering the unit off makes the noise disappear. Its not super loud, but definitely noticeable. HAVE TRIED: disconnecting pin 1 of both the XLR outputs. Am I missing something here? I tried to keep wiring as neat as possible, twisting power cable and running them to the outside corner. See photo for my wiring.
2. Bypass switch not working
I may not have this hooked up right - there isn't much documentation from drip regarding hooking up the bypass. Other than directing that at least one of the GND pads needs to be grounded. I grounded 2.
3. LED lamps
My LED's in my VU meters appear to have burned out. Inside the VU meter there are two LED wired in series. Im getting 6.3 volts across the LED terminals. If I stick an led across the terminals, it lights up, but quickly gets very hot. The LED's were working, but are no longer lighting up. Any Idea what would cause this?
4. Incorrect voltage at R13 resistor.
On both channels, I'm getting around 180v instead of the prescribed 120 at the R13 resistor. Any ideas here? I'll attach a schematic so you can see which one it is.
Thank you in advance for any guidance here! It is GREATLY appreciated.
Photos/diagram/schematic of my unit uploaded here:
Dropbox - GroupDiy LA2A Drip opto 7 photos
1. Hum
3. LED lamps
