Tube installation help. Please.
MoTeD
Who cares
I just purchased a pair of heathkit ea-2 mono amps. I am not able to figure out where the tubes go. Nothing is labeled inside and I am not sure of how to read the wiring diagram that I have found on the internet here
WIRING DIAGRAM
Is anyone able to help me identify which socket is which.
Thank you in advance for the help.
If you are looking at it from the back the rectifier (6ca4) will be the socket closest top you and on the right. The two in front of the transformers on the left are where the EL84 power tubes go.
Not sure on the small tubes yet but I'll keep looking and let you know.
The rectifier is as REX says.
Look underneath at the two tube sockets that have two wires from the output transformer connected to. These are the 6BQ5 tubes.
The 6AN8 is the tube which goes in the socket that has the resistors and coupling capacitors (C18 & C19 on the diagram) connected to the 6BQ5 tube sockets.
The only other tube sockets left are the 6AU6 & 12AX7. These two are self explanetory as the 6AU6 is a 7 pin tube, and the 12AX7 is a 9 pin tube.
Thanks for the help. I got them installed and working. After about 5 minutes one of the output tubes got so hot and was glowing so bright I thought it was going to pop. I took that tube out, put another in its place and all is well. Any ideas on what was up with the one tube acting like that?
Have these amps been gone through to update the old electrolytics, coupling caps, etc? If not, and you are new to tube amps, I wouldn't run them until that's been done. The fact that one tube ran hot like that (red plating) would normally indicate there's a problem with the amp, perhaps swapping the tubes only masked it for a bit.
Yes these amps have been gone through(danno55). I will monitor the issue and take notes.
If you replaced the tube and it stopped redplating; then the amps are fine.
I've seen tubes redplate when they're bad; or sometimes they just need to be reseated. If that same tube redplates in another socket; tube is bad. If it runs fine; then it was a simple connection issue.
Sent from my SPH-M910 using Tapatalk 2
Good to hear. Hopefully just a wonky tube then. By the way there is an EA-2 manual in zip format floating somewhere around the web but I'm not able to locate it right off. Might keep your eye out for it.
Ok. I was only able to find a wiring diagram last night. I'll be sure to look for the maual though.
