Hello everyone,
I have a pair of Sherwood S-1000 integrated mono amplifiers that I am using as mono blocks for vinyl playback. I have restored both and they sound fantastic when used in stereo.
For true mono playback, a double-Y cable or an external mono switch must be used to sum the signal coming from the turntable RCA connectors to the phono inputs of each amp. When this is done, it causes a massive hum that makes true mono playback on both speakers impossible. When using a Y- cable to sum the phono signal into just one amp, it works perfectly and there is no hum. I actually don't mind and prefer listening to mono playback on one speaker, but I hate having to disconnect the phono cables and insert the Y-cable into one amp every time I want to listen to true mono. That is why I bought the external mono switch, so I could switch between mono and stereo playback with out removing the cables.
When using the mono switch, the hum is present even if just one amp is on. Both amps have a 3- prong power cable with a ground connected to the chassis. I suspect there may be a ground loop issue going on. I tried using a 3 prong-to-2 prong adapter to lift the ground on 1 of the amps and it made no difference. I only have one so I wasn't able to try it on both amps.
Any ideas on what I can do to make this work? On my other integrated stereo amps with a mono switch (Sherwood S-5000, Eico HF-81, Marantz 1060), the mono switch makes a huge difference in the sound quality when playing back mono records and would like to be able to do this with my S-1000s.
