I recently got the following parts in to start in the fixer up Dynaco ST-70.
1) Orange drop caps for the board
2) New bias kit
3) Can cap
4) UF 4007 diodes
5) New choke
How ever I picked up a second Dynaco to give me something to listen to while I am working on the "fixer" upper. The problem is the "working" one has a weak left channel. During power up the smaller left 7199 tube lights up faster and somewhat brighter then the right 7199 tube. After the initial warm up, while looking at the amp while running I swear the hole left tube side is somewhat dimmer then the right.
EDIT: On closer inspection the two power tubes that appear to be glowing dimmer are made slightly different then their counter part. It just happened out of coincident that I paired them together. I swapped 7199 tubes and the initial "flash" follows that one tube.
2) New bias kit
3) Can cap
4) UF 4007 diodes
5) New choke
