If you wish to keep the original circuit its up to you. While the AVA mod will smoke it badly, you can enjoy the basic upgraded circuit and still improve its functionality. Re wiring some of the selector switch can give additional inputs, and the tape-input switch can also be converted to an additional input. Another useful mod is to move the power transformer outside on the back as the AVA mod has you do. More cooling to the transformer, and get a lot of heat out of the box. Also, disconnect the filters and loudness switches, as well as the tone controls. If you are keeping the original boards and circuits, you might get the curcio power supply which is regulated and way stiffer, plus it replaces the bias stuff as well. The stock transformer is adequate, but the filaments really pulls it down. An additional transformer can be mounted on the back just for the filaments...this will take a big load off the transformer. Also, replace the pilot light with a LED. I like green. Looks cool and draws much less than the little light bulb supplied. There is also a guy on Ebay that will sell NEW versions of the original board.
Russellc
