Gary Mattis
I decided to take the day and roll some 12AX7 pre amp tubes to try to decide what is my best sounding tube and I can't really say that only one brand of tubes would be my choice in every amplifier. I did decide on Amperex Holland in the end over Telefunken East Germany and Mullard Blackburn UK. I was not able to test Brimar UK or Smooth plate Telefunken East Germany because I only had one of each type. I did test Ei Yugoslavia smooth plates. I also tested RCA long black plate tubes being the best USA 12AX7s made here. Though I like GE long plate tubes I did not think that they were up to the task of sound quality against Vintage Mullards and Telefunken tubes. I used two Bogen CBH 100 mono blocks for the test and a cassette tape deck plugged into aux 1 on both amplifiers. 8 ohm full range 12 inch 30 watt speaker's. Nothing fancy at all just power amps into single 8 ohm speaker's. I wanted to hear the tubes without any additional speaker coloration. By using the aux inputs instead of Mag I was able to run a single 12AX7 into the splitter on each amplifier. The splitters are pretty cheap tubes a Triad Japan and RCA . Waiting for two Mullard 6C4 to get here. The outputs are 7868 RCA and two either Sylvania or Westinghouse with square plate holes. I'm not sure if the tape would sound better on the Mag inputs but I was trying to test single 12AX7 tubes. They all sounded good in the amplifiers and with speaker network's and input coloration you could use any of those tested and be pretty happy with the results. I just liked the Amperex Holland tubes the best. The overall sound and balance just seemed better with the Amperex tubes and the mids seemed to hold up much better in the mix. On certain songs the Mullard and Telefunken tubes really shined but it seemed like the Telefunken tubes were a little dry sometimes and The Mullard Blackburn were just a little bit dirty. The Ei tubes were not bad at all but we're kinda inbetween the Telefunken East Germany and Mullard Blackburn UK tubes. The RCA black long plate tubes were not bad just not in the same league. I only wish that I had another Brimar to compare with the other tubes. Brimer are good tubes also. The Amperex Holland Bugle Boy wins my vote for The best sounding 12AX7 tube. Also do consider the early Mullard long box plate tubes and the smooth plate Telefunken tubes. I did not have two of those or Brimar to compare. The Amperex tubes were quieter at idle also. There's a lot of factors in audio that color the sound and some of those things may actually pick your tubes for you , your amp and speaker's may only like one or two tube types. My amplifiers both seem to be pretty friendly with just about any tube that I installed in them , The long grey plate RCA did not sound very good when you compared it to the other tubes I tested. I honestly expected for the Telefunken or Mullard to win hands down and I didn't really see The Amperex as being a big threat to either one. So much for my expectations.
