BKville
A local guy has two tube testers that both have the same problem.. When he test a tube the meter will max out to the left with all tubes.. Even tubes that have tested good on other testers..
Any suggestions to check would be appreciated..
One is a Knight Kit and the other is a Jackson model 49... Not sure if the models are right though..
Thanks, Brent
Thanks, Brent
