Tube vs. SS General Purpose Headphone Amp
JRHemmen
I'm back after my really long hiatus, as I've got a pair of the Massdrop HD 6XXs on the way, and I need a headphone amp to drive them. My musical taste leans heavily towards rock (alternative, post-hardcore, classic) and hip-hop, but I do listen to the occasional acoustic session as well. I often hear people saying that music like that requires the speed of a solid state amp, but I've never seen a definitive answer. I'll also be using the headphones for gaming, as they'll be replacing my HyperX Cloud II's.
I thought I had decided on the Bottlehead Crack, but now I'm looking into Schiit (Asgard 2 & Valhalla 2).
Two sources that I will move between:
Desktop PC > Meridian Explorer DAC > Headphone Amp > Headphones
Pro-ject Debut Carbon DC Turntable > Little Bear Tube Phono Preamp > Headphone Amp > Headphones
If this belongs in a purchase advice thread, mods, please feel free to move it. It's been a long time since I've been out here and I forgot how things work.
Any input is appreciated!
I'm now running a tube amplifier, passive preamp, tube phono preamp and a hybrid headphone amp and very happy so far. The. Headphone amp has a tube front end and a single ended SS output. Around $65. There are several variations of it. A headphone jack on the front and one input and even a line level output so it can be used as a preamp to drive an amp. I replaced the Chinese 6J1 tubes with GE JAN 5654W's for about $6 per tube. Its very quiet and sounds really good.
What impedance are your headphones? It's important to match them up to the amp in that regard. For a high-impedance headphone you need an amp that can supply a lot of voltage. For a low-impedance headphone you need an amp that can supply a lot of current. Full tube designs usually match best with high-impedance headphones. If it is a hybrid tube amp, then it usually has a solid-state output and just uses the tubes as a built-in buffer, just for effect, and it should work better with low-impedance headphones.
Remember that in full tube designs, if you drive it too hard you will cause the tubes to clip. Tubes experience soft-clipping as opposed to hard-clipping with solid state designs. Soft-clipping can actually sound good to some people, in some situations.
I use an older Little-Dot II+ full tube headphone amp, and I also use a Yamaha C-4 preamp as a headphone amp. I switch back and forth depending on which headphone i'm using and depending on my mood. I tend to prefer solid state for songs with extremely heavy bass, as that can take a lot of power and if that pushes a tube headphone amp into soft-clipping it can sound mushy - though that does work well with some songs.
You could always get a solid state amp, and a cheap tube buffer (example), compare how you like it with the tube buffer in the signal path vs not. That would be pretty close to what you get with a hybrid tube amp anyway. If you do get one with Chinese 6J1 tubes, I agree that upgrading them to pretty much any 6J1/EF95/6AK5/5654 tube will be an improvement.
I use an objective2 and a chinese 6j1 tube buffer. I can go between tube sound, and ss with a simple cable swap. I also have a little dot i+, and a few other ss amps. The o2 + 6j1 is my current favorite.
This is the most helpful comment I've seen anywhere so far on the topic, thank you.
The headphones are the Sennheiser HD 650s, 300 ohms.
I don't need an amp that necessarily has a solid upgrade path because I'll be holding on to this can/amp combo for a long time.
Vahalla 2 offers 800 mW RMS at 300 ohms.
O2+ODAC offers ~150 mW max at 300 ohms.
Asgard 2 offers 380 mW RMS at 300 ohms.
Bottlehead Crack offers ~333 mW RMS at 300 ohms.
I'd think with the power output of the Valhalla that I wouldn't have to worry about any clipping, but I obviously have no real testing to confirm this.
Have you tried the 5654W's in place of the 6J1's yet? Its a cheap and nice sounding upgrade.
