If someone got a loose connection stock power cord and would like to replace it with a new one, we will have extra power cords in stock in a few weeks to provide you with a replacement
Will do. Thank you!
However, I know from experience that, although this tube is certainly doing more than" scratching the surface" of the GF TD-11; I can look forward to substantial improvements in the hands of Mullard, Amperex, Telefunkin e.t al.
more to come...
As I've often said before, I LOVE the TD-11.. particularly its sweet 'tube output'. For headphone enthusiasts (like me), the types of headphones I can use with the 'tube out' is limited due to it's high output impedance (a commonality with most all OTL tube amps). For example, I can run my high impedance Sennheiser HD580 (300ohm) straight from the 'tube out' without any clipping or distortion.. they sound incredible! When trying to use phones that have low/medium impedance (custom IEMs & my orthodynamic headphones.. namely the HE-500) directly from the 'tube out', the sound quality is quite bad as it distorts & clips at very low (unlistenable) volumes. The poor damping factor also impacts the sound quality fairly severely.
How did the HE-500's sound from the SS headphone amp from the front jack of the TubeDAC-11 ? And do try the other outputs with your new headphone amp and let us know what you think. We recently launched our PH-6 tube headphone amp ($185 shipped) which sound awesome fed from the TubeDAC-11's DAC Direct output. For just over $500 you end up with quite the amazing headphone rig that has 3 different headphone amps that will drive just about anything
As you noted it is hit and miss on low impedance headphones on the Tube outpus, but it is just the very hard to drive low impedance that seems to be an issue at which point you need to go to the SS output on the front.
Thanks for your feedback FlySweep.
Cheers,
Ian
Thanks Ian. It really won't be an issue in the long run but as you can imagine, was using Pause more yesterday because I was trying to do some AB to confirm if I really was hearing a difference and not imagining it.
What is that clicking noise anyway, at first, I thought it was coming from my CDP but it was coming from the DAC. Interesting to me was that it sounded like a physical clicking and not an audio, is there something in the DAC that is making that sound?
it is a must to upgrade the power cord.
I realize that this is an old thread, but since no one commented on it, I would like some clarification. I am considering getting a Dac-11. I already have the DAC-09 and was thinking of getting another DAC.
I use the power cord that came with the DAC-09 and it has worked just fine. What would be the differences between the DAC-09 and the DAC-11 that you would need to upgrade the power cord? Could I use the power cord that came with the DAC-09 on the DAC-11?
What would be the problem in using the supplied Power Cord? Would there be a Fire Danger in using the supplied Power Cord with the DAC-11?
I am guessing that the DAC-11 supplied power cord is probably 3 Copper wires that are about 14-16 gauge wire. What would an 'Upgraded Power Cord' consist of? Could I make this power cord myself?
Here's an analogy for you. Take a 426 Hemi and feed it with a little 2barrel carb,and you virtually starve it for fuel. Now give the same engine a 4barrel carb and you'll see much better performance, much the same is true for audio equipment![]()
