... I want to learn how and do radio alignments. I know I need some test equipment and that may be my starting point. I already have a dual trace o scope, tone generator, VOM and signal trace.
thanks
What kind of radios ?
In general, you need an RF generator with variable calibrated RF output level. It should have the ability to create AM or FM depending on the radio. And for FM stereo, a stereo generator.
You also need a way to measure distortion, and frequency. If you want to sweep the IF section on tube radios to adjust the transformers, you need the sweep capability and probes to do that.
But most important, you need to understand how an AM or FM radio works. Use internet searches here.
If you try to follow the service manual exactly, in many cases you will be confused by their instructions, use of terms, or equipment, etc. But if you understand WHAT they are trying to get you to do, it will make more sense.
The easiest tuner to align (for starting out) will be a solid state analog one from the mid 70's.
An inexpensive one that you can buy cheaply and play with, probably a receiver that maybe even has a burned out amplifier section. Try to get one that at least has a free service manual for reference. Learn how it works on a unit you can toss and start again, in case you screw it up. Learn how to clean the tuning gangs, first thing! then how to adjust the RF front end, etc.
As other mentioned, get plastic alignment tools. These come in all shapes and sizes, you may need to get multiple sets to cover everything out there.
Bob
