Brivan
Well-Known Member
I didn't post this in any particular forum since I'm thinking the values may be relatively close from one receiver brand to another. I have an Onkyo TX-4500 that I suspect as having a defective tuner trimmer capacitor. The trimmer cap I'm referring to, specifically, is T6. This is the trimmer cap that will give you dial position adjustment for stations on the higher end of the dial (an inductor usually handles this role for stations on the lower end).
The tuner was working normally, but the dial position was off slightly on the high end (low end and AM positions were fine), so I attempted to move the trimmer cap, but it felt stuck and took a little persuasion to move but, when I did that, I was never able to regain proper adjustability - I could locate my station a couple megahertz away but the signal was weak and I couldn't get it moved back anywhere near where it was supposed to be. Non-residue contact cleaner and compressed air didn't help.
This is the second TX-4500 I've had this happen to. I didn't realize until this last failure that this appeared to be a common failure point, otherwise I would have left well-enough alone. I have a spare TX-4500 and was able to very carefully remove the trimmer cap from it and install it in one of my other "bad" receivers and get the tuner running normally, again. But I'm short one trimmer cap and am looking for a replacement.
I'm unable to measure the value of the good trimmer, likely because the value is so low. I've got an ide that they are somewhere in the 1pF to 5pF area but am not sure about it. Would anyone have any idea of the value of one of these trimmer caps and, even better, where a close replacement might be sourced? Sprague-Goodman has some in their GKU-series trimmers but they're obsolete. Thanks!
