Turntable centre spindle size/thickness?
catman
Addicted Member
Banned
G'day all, for quite a few years now I've used those rubber door stoppers as quite an effective record clamp, and one interesting thing that I've noticed is that pushing the stopper centre hole onto the spindle is a reassuringly tight fit with some turntables, but less so with others.
To me this suggests that there is some 'variance' in the dimensions/thickness of these spindles. As they supposed to be a 'standard' size? :scratch2: Regards, Felix aka catman.
There is probably some small variation, just as in lp's, some fit tighter over the spindle.
There are distinct spindle sizes, depending on where the tables were built.
I did have the actual range noted at one time.
So if one was to make say a center weight, you would pick the largest size to accommodate the higher end of the scale.
"There are distinct spindle sizes, depending..."
"There is some small variation..."
That's speculation. But nobody here has the ANSWER to Catman's question.
It is almost as easy to find the DEFINITIVE answer as it is to speculate. Google is your friend, and found this in a matter of seconds:
RIAA dimensional standards
G'day mate, very interesting stuff and precise too. Many thanks. I presume that these are 'record' dimensions or do I misread? Regards, Felix aka catman.
Spindle size
Hello all,
The standard size for a turntable spindle is 9/32", which is 0.2812", or 7.143mm, with a suitable tight tolerance such as ISO f7.
Several manufacturers (e.g. Thorens) deliberately make the spindle at the top end of the tolerance range for this dimension so that records are a tighter fit on the spindle.
regards
Angus
G'day mate, thanks for that. That's very good information. :thmbsp: Regards, Felix aka catman.
Catman, I've noticed the difference as well. What type of rubber door stopper do you use? Do you simply drill a hole in it?
BTW - the possible double meanings on this thread are just begging to be mentioned.
:nono:
GP49
That's speculation
It is a fact that manufactures from various regions Germany/Japan etc
chose to use a spindle size that differed from others.
This could be on the lower or the higher end of the {designated range}
giving the variability the OP has found. No speculation here.
Hello all,
regards
Angus
I think my ARXA is this way too.
From what I read once it had a lot to do with gently pushing the label-spindle hole down onto the spindle and then it gripped the LP to the platter better.
I've got a Thorens 150ll that is that way also. They really grip the record without using a weight or clamp.
Don't quote me, but I think the ARs adhered to an earlier, different, broadcast spec, and were a bit thicker. Maybe one of the broadcast, or AR, experts can confirm. Or tell me I'm an idiot. Either is fine.:D
The AR XA spindle is compliant with the NAB/RIAA standard. NAB codified the standard along with their participants, and RIAA then adopted this throughout the record industry.
I know for a fact that some manufacturers purposely had an 'oversized' spindle and advertised it as such. It probably was more of a 'top of the tolerance' than 'oversized'. Pioneer, I believe, did this in the late 70's on their TOTL stuff.
Felix, is the doorstopper you speak of the one that as kids we all liked to make go "Boiiiiiiiiiiiiiiiiiiiiiiiinnnnnnnnnnnnggggggggg!!!!!!!!!" ?
The AR-XA spindle is .282 and my digital caliper also has a tolerance, especially at the 3 place decimal. I'd, therefor say, it's spot on.
As far as other manufacturers, who said they all should follow RIAA/NAB specs? It would be nice if everyone followed some form of standardization, but then all of these companies have marketing people, who think they know better.
Wayner
