I have a Micro Seiki DD-40 turntable with the M-505 tone arm. I have had it about 28 years, and it still is a fine performer. A major problem that Micro Seiki had with the DD-40 was a poorly engineered dustcover. I have seen 10 different DD-40 turntables through the years, and everyone has had the same dustcover problem as mine. Where the two hinges attach to the plexiglass there was not enough thickness to handle the stress of the hinge spring pressure, so gradually cracks appeared in the plexiglass next to the hinges. The cracks continue to grow until the plastic finally breaks at the point where the hinges are attached.
I have removed both hinges from my dustcover, glued a custom fitted piece of maple veneer over the back inside surface to hide the cracks from view, and have to lift the dustcover off and on when I use or park the turntable. I have been doing this for over 20 years now, and want to fix it somehow.
Are there any manufacturers making replacement or custom made turntable dust covers? Maybe there is a NOS (new old stck) cover somewhere that might be available, maybe laying around in a distributor's warehouse. I need some help.
