What did you use for the wood? It looks pretty thick .just resting, trick is to lower the platform to exactly where you want it...cant slide it around...the TT plus the platform are pretty heavy together so it doesn't move around at all...
Nevermind I read your previous post , maple cutting board spray painted . Where did you get the cutting board from ? Link to where you got it ?just resting, trick is to lower the platform to exactly where you want it...cant slide it around...the TT plus the platform are pretty heavy together so it doesn't move around at all...
Problem is the plinth in the pic is now twice as big due to the spikes. Without getting too technical energy cant be created or destroyed it just moves to another form. Example electricity when you turn the light on becomes light and heat. Now vibrational energy from music enters your plinth and the slab under it coupled by spikes. The hard slab transmits this energy very well indeed up the splikes almost unhindered to the turntable plinth and on to the cart.. Now substances like Sorbothane are excellent at damping vibrations, but what does this really mean? What it means is Sorbothane is good at transferring that unwanted energy to a form that is not a problem ie HEAT. The Sorbothane wobbles with the vibration but wobbles reduce and heat is made all good for what we want. The big slab looks nice but to get the beat from it you need Sorbothane footers under the pucks under the spikes.
