Windwalker
So finally got into the bottom of my PL-518 and Pioneer chose not to solder the interconnects to the board
They use a molex connector.
Now I'm a bit stumped:scratch2:
Should I?
1. Just clip the current interconnects at the back of the table, leaving a pigtail and either
a. solder the new wires direct to the tails or b. solder some RCA jacks to the tails and just use new interconnects
2. clip the wires inside the table at the molex and doing my soldering from there
3. try to find the same size molex and build my own
4. remove the current molex and solder wires to pins
5. just attach some pins from a computer molex to new cables and push them down on the table connector
6. go get another beverage
7. Just leave it as it is-plays fine, sounds good was just trying to squeeze a bit more from it
8. combine 6&7, repeat as needed
I did end up going with the 8' cable from RS, It looks like This, labeled Monster THX v100cv. Was 10 bucks-cut in half and have enough to do another table sometime. $5/table is not to bad
Routing is going to be quite an ISSUE, I'm afraid. such thick cable-almost wonder if it's overkill
Likely will not be able to keep current clamps and such in stock condition-there goes the resale value
Input, ideas,thoughts, a toast...........
Should I?
