Hi Folks, I am restoring a Techincs SL-D2 turntable that had been parted out and had a bad RCA connector. As a replacement for the RCA, I thought I might be able to use a spare RCA connector that is of decent quality. It is one of the connectors that that has a double end at the connector side, but the main run is a single cable. The ground/shield wires combine at the junction, and the main run is a three-conductor shielded cable that splits again at the other side. Will this work as a replacement?
I notice on phono preamp schematics I have that the ground is common once it enters the preamp (but different from the chassis ground), so I am thinking of jumping the common ground at the connector board in the turntable where the tonearm wires connect to the RCA out. Any reason not to do that? It would be a neater solution than the traditional independent conductor cables normally attached.
