Hello,
A little while ago I got back into vinyl after a 40 year hiatus. Wasn't sure if I'd stick with it so invested modestly in a new Audio Technica AT-LP120 turntable. I also bought an early '80's Sony ES amp that was in near perfect condition after a few squirts of deoxit in the pots. I connect the amp to a pair of Sonique SA4 floor standing loudspeakers from the 90's that I brought out to the US with me from Australia. You likely haven't heard of Sonique but they had a great following back in the day.
I've since added about 200 LP's to my collection, many of them new 180g pressings. Its seems the bug has bit and stuck. I am really enjoying the sound of these records and consider it a significant improvement over streaming audio which had become my go to medium (hard to beat Amazon's music collection!).
I really like the amp and speakers but am thinking its time for a turntable upgrade. I am considering two options and would appreciate any opinions on either path.
Option 1: Upgrade the LP-120. At the end of the day, this isn't an awful table, looks new and works well. I have been able to eliminate any motor rumble, the geometry of the tone arm is spot on and even the anti-skate works on mine. Considering just upgrading this with an Audio-Technica VM540ML headshell/cartridge combo, a high quality platter mat and maybe a record stabilizer weight. Total cost US $340. I would also bridge out the inbuilt pre-amp / low pass filter that is used by the USB circuit and not needed in a pure analog setup where the amp has MM/MC inputs. There is a great YouTube video that uses sound wave data to prove that the low pass filter rolls off higher frequencies needlessly.
Option 2: Buy a used Technics SL-1200 MK3D in (claimed) excellent condition (quite a few around from Japan currently) and add the same cartridge as above. Total cost US $800 with some risk associated with buying a used table with unknown history.
Money isn't really the driver here. So money aside, is there really likely to be a discernible difference sonically between a real SL-1200 in good working order and an LP-120 with the common complaints (rumble, anti-skate, pre-amp, mat) fixed, and both running the same decent, mid-range cartridge?
Thanks in advance for your opinions!
