Boomzilla#1
Hi Y'all -
I have a new Yamaha RX-V6A. I also have an older 65" Samsung TV (one of the ones with a proprietary input connection and an umbilical cord to the HDMI input box).
On occasion, I want to have the TV audio flow to the AVR. I spent this morning trying to enable ARC. Input 4 of the Samsung's input box is the ARC connection. I plugged in there and then selected that output and turned on ARC.
On the Yamaha end, I plugged in on the "output" HDMI that is the only one with ARC capability. I then referred to the Yamaha manual and went through, step-by-step, enabling ARC. I then went back to the beginning and double-checked each setting.
Testing ARC, I got nothing on the outputs of the Yamaha. I know that the Samsung is sending because there is a graphic of the audio signal showing that it is playing to HDMI4. After futzing around all morning I gave up on ARC.
PLAN B - If I can't skin the cat with ARC, I'll do it with optical! I first went to the Samsung & verified that its audio was broadcasting to the TOSLINK output of the umbilical box. The Samsung's audio signal graphic showed output to the optical jack.
I then checked the optical cable to verify that red light was coming out at the Yamaha end - it was. I then plugged the cable into the Yamaha's optical input, checking (twice) that the cable was properly and fully inserted with the click that showed "fully inserted." Then, referring to the Yamaha manual, I assigned "TV sound" to the "Audio 1" input.
I then tried to select "Audio 1" from the input menu, but it is not there! I double-checked to ensure that "Audio 1" was enabled - it was; then I double-verified that all the settings were per the Yamaha manual. Tried again to select "Audio 1" as an input source, but again it was NOT there.
What dumb thing have I missed? Thanks in advance for your help!
.... Taken from " Analog Man " - Joe Walsh
