TV speakers anyone?
PioneerGuy75
Certified Lurker
I have quite a collection of those little oval TV speakers. (any time I toss a TV i gut it first.)
Anybody use those for anything? Line-array or anything?
I am sure they are not really Hi-Fi, but they are too cute to toss out...:scratch2:
Cheers :beerchug::music:
PioneerGuy75 I would assume you wait until your TV has stopped working for viewing purposes before you remove the speakers.
How often do you have to replace a TV ? How big is your collection of TV speakers?
My last question is what have you done with your collection of TV speakers?
First, I grab them from the trash periodically...
I have about a dozen :scratch2:
Sitting in a drawer in the basement.
Some TV speakers sound pretty good. Call them "single drivers", put them in "open baffles" and "use tubes" and you'll be cutting edge.
But seriously, some TV speakers do sound Good.
I agree. Mine sound awesome.
I wonder if any of the TV speakers came from pre solid state TV's.
It would be curious to know. In that case there would only be one speaker per TV. I forget the size of the speaker in my parents old tube TV when I was a young child.
I do like Audiomagnate's choice in TV speakers.
In my opinion “some” TV speakers do sound pretty good for what they are.
I built a few small cabs for some I had and paired them up with a sub and crossover and they sound pretty good.
Here's a close up of one of my TV speakers. ;)
attachment.php
I have the same problem, PioneerGuy. Can't seem to throw out stuff that works. I've actually amassed quite a collection of not only TV speakers, but console drivers, everything from 2" cone tweeters to 15" woofers. I always intended to build a big line array at least using the mids. It seems to my uncultured ears that there is less to go wrong with a mid vs. tweeter or woofer, so they are more likely to sound OK. Problem is the tweeters usually don't do much above about 13KHz, so you either have to use something else, or buy supertweets.
Due to the plethora of GOOD speakers needing work and/or building at my place, these projects tend to sit with their questions and mysteries unresolved.
The big old projection screen TV's have some nice 6 or 8 inch whizzer cone drivers in there. I am impressed by a big Hitachi TV we have and those would make great single driver setups.
I can't remember the last time I listened to TV speakers. I use my TV as a video monitor only. I use the audio from the cable box through my HT receiver and my Polk 5.2 system. I don't bother to connect the TV audio to my system.
Some TV speakers do sound nice, but we all know that as far as true audiophiles are concerned, nothing comes close to a seperate audio system when it comes to movies and stuff. I will say though, my brother has this newer Sony TV that has a built in Sound system, complete with subwoofer, and it does sound pretty dang good for what it is. Also, my dad had this little Magnavox TV from around 1985 that had a DBX sound system built into it as well. For a 20" TV it sounded really nice and clean.
Remember that TV audio bandwidth is pretty narrow so TV design engineers spec'ed speakers that didn't need to do more than that.
Maybe at times the engineers snuck one by the bean counters and overqualified the TV speaker for its intended application but that would be rare.
I was thinking that (at least in the old days) TV's audio bandwidth was the same as broadcast FM...ie: 50 to 15k Hz.
It was an AM signal, broadcast AM bandwidth and quality at best. The video was an FM signal, but wider in bandwidth than broadcast FM, if memory serves.
Re: TV speakers:
Two words: art project. :beatnik:
Re: NTSC video/audio modulation:
"When a transmitter broadcasts an NTSC signal, it amplitude-modulates a radio-frequency carrier with the NTSC signal just described, while it frequency-modulates a carrier 4.5 MHz higher with the audio signal."
I :heart: wiki :D
http://en.wikipedia.org/wiki/NTSC
Then how come TV sounds so much better ( Read un-TVish) when hooked to good speakers??
I think it has a lot to with proper enclosure (or lack thereof).
:music:
