Hi all. I recently acquired two reel-to-reel tape recorders - a Craig 2107 and a Voice of Music Tape-O-Matic 760. Both are small, low-end, but capstan-driven units. Both work, but are suffering from the same issue - they have longitudinal play in the capstan.
The Craig's play is massive - on the order of a 1/4 inch. I have to lay the machine on its back to play; otherwise the capstan walks forward, and the flywheel scrapes against the chassis.
The VM's play is about 1/8 inch. It causes the flywheel to sit low, so the FF idler doesn't engage with it properly.
Anyone know what might the issue be on these machines? Is there a felt washer in the capstan that has gone flat? I thought since I have two machines with the same issue that it would be a common issue, but I have found absolutely nothing through Google.
Thanks!
Thanks!
