I wouldn't assume this without seeing the system first.You are dealing with a 220volt device, most likely. 220volt systems use a round prong plug.
Oh no, those clairvoyants above are certain it's a Schuko type F without seeing it.Euro mains plugs may be round, two-pin plugs but that doesn't mean all round, two-pin plugs are Euro mains plugs.
The current incarnation is a C7 connector, although I don't know if the old "cheater cords" have the same 10mm pin spacing. Seems unlikely, though.That's just a removable common as rocks power cord, available everywhere.
I just compared old cheater cord vs. newer style cords. Same pin spacing, newer cords are for smaller diameter pins. Op could probably find a newer one, heat in hot water to soften plug material & cram it on, will be a tight fit if it works. That's the only physical fit issue, as any new style cords are smaller than old, at least those in my stash. Other option is bypass the pin socket & hardwire a cord.The current incarnation is a C7 connector, although I don't know if the old "cheater cords" have the same 10mm pin spacing. Seems unlikely, though.
Here's a site that carries a whole bunch of them. Most of the cords there that are similar have an approximately 8mm (5/16") spacing. OP should measure the spacing of his plug to be sure. Note that pin measurements are center to center, or left edge to left edge, not just the space in between the pins.
