Carbsandcaps
Working on a tx-200 that I received in no working order. I’ve got it all recapped and replaced the output transistors. Some questionable resistors and set the bias the 135mv on each set. When it’s on below half volume it sounds wonderful. When you start to turn the volume past that it’s start going crazy. The sound starts pulsing along with the stereo light. I assumed this was due to the 6800uf caps I put in place of the 2000uf and the transformer couldn’t keep up. I put some 2200 in and still does it.
I also noticed that the positive voltage out of the diodes is 32v and the negative is -39v. When the distortion starts the positive goes even lower and the negative goes up to -42! The voltages are supposed to be 35ish each. There is a 7 watt resistor that goes from the negative output to ground. Going from 180ohm to 150 seemed to help a little bit but still does it. It will also do this with no music being played just the speakers hooked up. It goes thump thump thump. I assume the big resistor is suppose to balance out the voltages since the positive side is running basically everything that isn’t the outputs.
Anyone got any ideas or know what the heavy resistor’s job is! Thank you.
