TX 9500 II Function Switch Question
TeslaPower
AK Member
Hi All,
Can anyone advise if the Function switch is the same for the Pioneer
TX 9500 and TX 9500II Tuner....or any other Pioneer Tuner function switches that match up? I need to replace a function switch on a TX 9500 II I picked up.
Thank You for your assistance.
The 8500II and 9500II uee the same part for the Rotary Function switch.
TX-9500 uses a different part #.
ASD-063 = TX-9500II & TX-8500II
ASD-037A = TX9500
Best way to do this is to look up the part # in your manual. Write it down, then go to
http://parts.pioneerelectronics.com/ and in the part # search box type in your part #. There will be box that shows which models use that part, and if there is a superseded part # it will list that part#.
Larry
Larry,
Many thanks...that's awesome of you buddy.
I did search it. It shows out of stock over 60 days.
The search continues....
