UGH... Tube replacement help
LRVGTR
Member
Hi Folks,
I have a Fisher "Beckman" amp and had it on without speaker cables for several hours. Possibly five or six hours. There was no signal either at the time. The good news is when I hooked the speaker cable back up everything seemed to work fine. It sounded okay. I didn't hear anything strange. But surely I must have done some damage? A couple of the tubes have a slight bit of coloring like maybe they got too hot.
Can anyone comment on whether or not I dodged a bullet?
Secondly, should I just change out the tubes? If so, the four JJ EL84's are a cinch to replace however, the two GE 7247's not so much (9 pin). I can not find them anywhere on this planet, or at least on the internet. The only thing I could find was vacuumtubes.net directing me to some 12DW7's. However, there is a note on the Tube Depot site that concerns me...
"This is a suitable replacement for any 12DW7 / 7247 tube type. We have various US brands on hand but have enough to match for brands and noise tests.
Please Note: Due to the fact that the 12DW7 has two triodes with completely different gain factors, this tube cannot be balanced"
Did my GE 7247's have two triodes as well?
Thanks in advance for any advice I can get - john
This is the amp below...
If it works and sounds good, you're fine, the risk wouldn't be to the tubes but rather the output transformers. If you get sound you're fine. No reason to change your 7247s, yes they're not made new that I know of, so you'd have to go to resellers but no reason to.
Thanks for the support @Selmerdave ...Do you know if my GE 7247's had two triodes as well? or is this a 12DW7 thing? I think this is the pre-amp tube yeah?
Ok thanks @Selmerdave Should I assume that you are saying my current 7247's also have two triodes as well? I just can't find any intel on these anywhere.
LRVGTR, the 7247 tube is known as a dual triode meaning that each section inside the tube itself is known as a triode.
If you look at the tube itself, you will see two separate plate structures inside. Each plate structure is known as a triode thus two triodes or dual triode tube. The 7247 is known as a dissimilar dual triode which means that each separate triode inside has different gain. One triode section might have a 100% gain ability while the other triode section might only have 60% gain ability. The tube is purposely designed this way for various circuits without having to use two or more separate tubes to accomplish a single task.
I am assuming that the discoloring you ars seeing on the tubes is just the getter flash spot. This is completely normal as all tubes have this.
If you look up "tube data sheets" on the net, it will explain everything about tubes.
Hope this helps.
Hope this helps.
@cademan It does indeed! many thanks
Hi Folks,
The amp does not seem to have got any damage by the unconnected speakers. The fact that it had no signal
would make the amp safer then if there had been large signals. Thus you seem sefa.
The 7247 tubes may be obtained from JJ ( eurotubes.com ), JJ designation is ECC832 .
7247 is a tighter speced 12DW7 , ECC832 is the JJ designation, they are all the same tube contaiining
one triode of ECC83/12AX7 and one of ECC82/12AU7
In addition to new JJ versions, Electro Harmonix also makes a 12DW7/7247, and new manufacture and Vintage versions are easy to find on ebay, so replacing them if necessary is not a problem.
For those who know, would you go for the JJ 12DW7's or the Electro Harmonix 12DW7's? What differences could I expect from both?
I'm using JJ 12DW7's in my ST-35. I havn't had a bad or noisy JJ signal tube yet.
I've also used JJ 12AU7's and JJ 12AX7 types. I'm using a pair of JJ 12AU7 long plates in each of my mono blocks right now. I'm not saying JJ's are the best, but they have been consistent and sounded decent in my amps and preamps. I have however had problems with EH signal tubes being noisy in a few amps. They're cheap enough, you could buy a pair of each and let your ears decide.
To be correct; JJ names their tube ECC832. That is what you should order from eurotubes.com
The differences might end up in warranty
Only a badly malfunctioning amp would be damaged by being connected to no speakers, and left on with no signal.
Slight discoloration of tubes is normal, I wouldn't worry about that one bit. Truth be told tube amps are quite robust, you're going to have to put more effort into it if you want to damage something :)
Drive a tube amp into clipping; won't hurt it. Turn it on with speaker disconnected; won't hurt it. Do both and you'll be smelling smoke as it arcs over tube sockets, output transformers or other parts that happen to be in the way... (tubes will still be fine if the flames don't get that far...)
