So, it appears that the composite design is, essentially, modular, with the ability to add push-pull pairs of DC offset corrected LM3886s to the basic unit in order to increase the power, or at least the current, output. This provides a way forward to eventually enable the unit to supply 7, 14, 21, or 28 amps per side in a dual mono configuration. This should facilitate the evaluation for a DIY build.
The design, at least in simulation, is stable into any load that speakers present, but is limited by the LM3886 power supply maximum of roughly +/-28v.
The datasheet maximum is 68W/unit- single ended into 4ohms., which represents about 4.5A RMS or about 5.8A peak. This would be equivalent to 136W into 8 ohms in the push pull case, as the current limiting would be the same, and would fall into 4 ohms.
More parallel stages would improve the current drive and the thermally limited output from the amp but would not necessarily increase the maximum available swing.
For example, two output modules would allow for approximately 136W per side, for a total of 272 W, but this would be into a 4-ohm load, with the 8 ohms case being essentially unchanged.
This offers the opportunity for a prototype to be constructed to test out the concept without having to go for a full design.
The prototype need not even have the final supply, as long as a 10A +/- 30 v DC bench supply is available.
It would include a +/-15v regulator module, a DC coupled, offset corrected balanced /SE input stage and a push-pull input amp/phase compensation section for a composite amplifier plus a single push-pull LM3886 output driver module with connections to support other push-pull output driver modules wired in parallel.
It would also include the on timer and a mute function.
The gain would be x40- or 32dBs, with a full power sensitivity of about 500mv rms, which is compatible with many Audio preamps etc, if not with professional audio gear.
If this is of interest and
@hirscwi is willing to lay it out/build it as a first stage to a full amplifier, then I will post the schematics etc.
