mzeitlin3348
See it and Believe
I woke up this morning - went to turn on my preamp/stereo system - nothing.
I looked at the pre-amp and it is stone cold - no power whatsoever.
So I took the cover off and checked the fuse first. It is a Bussmann Ceramic 250V 1.25 MDA. I assume this is a slow blow 1.25 amp fuse.
I checked with my ohm meter and sure enough it had a lot of resistance.
I did not have a spare fuse so I decided to put in another ceramic I had laying around with a lower rating: 250V 0.5A (not a Bussmann) just to see if something is blowing the fuse.
I put the fuse in and my system came back to life playing music as before.
My question is can I just leave it this way? or do I need to find an exact replacement fuse and not use my pre-amp until I get it properly fused? And why did the original fuse blow in the first place? Can they just wear out? The pre-amp is 11 years old and original.
