My family uses several Pioneer (SX-727, 737, 750, 828) and Yamaha Receivers (CR-600, -800) and nearly every Model has a different speaker protection relay.
So I got the idea, why not exchange the original one with a universal relay if they need replacement. These are all general purpose relays, so I would order two types, depending on the original relay, either with 12 vdc and 24 vdc coil voltage and at least 5A or 8A. 6 Pin (max 8 pins) should work as well, these type has got a bigger contact surface.
I had once seen a solution with a solid socket and a plug in relay was used, unfortunately I cannot find this page right now.
My question to you, what do you think about that plan. Has anyone done this before and if so, what type of relay and socket did you use?
The main aim will be, to minimize the oxidation on the contacts inside the relay, as long as there is no sound deterioration.
What would you recommend? Maybe a sealed relay?
