University Medallion XII info needed
Rex Everything
are you Shpongled?
I did some searching around but found little info on these speakers.
Does anybody know about or have experience with the University Medallion XII 3-way speaker sysytem?
Looking for specs and impressions if possible.
Mitzi enjoying Ray Manzarek's "Perfumed Garden" through the University Medallion XII.
First impressions are these will make a great party speaker. They like power.
Looking forward to getting them placed corrrectly and finding the best mated gear for them.
More pics and info to come.
Paul, good speakers, a little softer than JBL L100s or Pioneer HPM100s. I have seen them as high as two large bills.
BTW, shoot me your cell #.
http://www.audiokarma.org/forums/showthread.php?t=107659
http://books.google.com/books?id=QS...#v=onepage&q=university medallion XII&f=false
That should cover you...
Thanks for that Popular Science link. Veyr interesting info in there. That ad is from '61 so that's a good reference until I decide to pull the drivers out and see the exact date.
Thought I'd follow up on this post with a few pictures for those that care.
http://i10.photobucket.com/albums/a148/ampegmang/100_1357-1.jpg[/IMG
[IMG]http://i10.photobucket.com/albums/a148/ampegmang/100_1358.jpg
I recently acquired a pair that are not as clean as the examples above, but the all important drivers are pristine and sound amazing good! I would have to guess that they're in the mid 90db range and are 8ohm. I drive them with a nice Dynaco ST-70 with ease. I prefer them over my Dynaco A-150's which are basically A-25XL's. The drivers appear to be Altec in design and are similar quality. Mine are from 1961...I would buy another pair in a heartbeat.
Those funny little tweeters are sphericon's and sound amazingly wonderful! :thmbsp:
I really like these speakers. I acquired a pair of these a while back with a lot of original literature that hasn't been mentioned (oops). They are each comprised of the following:
(1) Model C-12SW 12" Adjustable Response DVC Woofer
Built-in facilities enable high-end adjustment of response to 700, 2500, or 5000 cps, suiting requirements of most tweeters. Crossover points can be changed to achieve best tonal balance. Used with N-1 adjustable high-pass filter in 2-way system, forms a complete L/C network. 1.5 lb supersensitive all-Alnico 5 Gold Dot magnet. Response from 30 to 6000 cps. 30 watts rating. 8 ohms. 6 7/8" deep. Shipping weight 7.25 lbs.
(1) C-8 M Mid-Range
Response of 500-5,000 cps deliberately restricted to vital mid-range frequencies by means of viscous-treated surround and center. Fully enclosed basket eliminates need for additional sub-enclosure. Power rating: 50 watts. Depth 4 1/4". Shipping weight 3lbs.
(1) Sphericon Super Tweeter Model T202
Offers the most phenomenal high frequency response ever achieved (by 1962) from 3,000 cps to 40,000 cps (+- 2db to 22,000 cps) with amazing clarity, transparency and sweetness. The entirely new (1962) concept of this radiator tweeter, with its special domed phenolic diaphragm and spherical diffractor, results in a virtually linear response- with true musical quality-far superior to even the most expensive tweeters (in 1962). Matches perfectly to any system especially high compliance, without sacrificing bass efficiency. Built-in network and adjustable brilliance control. Dispersion 120 degrees in all directions. 30 watts* rating. Impedance 8 ohms nominal ( use with any 4-16ohm speaker).
Pulled that right out of "Your 1962 Guide to Compact Stereo High Fidelity"
:wave:
Dual voice coil woofers? What's up with that? How are they using the second coil? I'm really impressed with those tweeter specs.
I picked up a set at Goodwill for $20 and I love them! Beautiful sounding speakers, especially paired with my Yamaha CA-600 :)
Walked out of my local Deseret Industries with a pair for $8 total. Tomorrow I'll fire them up and see if everything is in working order. One woofer has a dented dome but I can pull that out pretty easily. Has anybody ever recapped a pair of these?
There have been several folks on here that have recapped them. If you search there are pictures and cap values posted. The shop I use recapped mine while replacing a blown tweeter. Very pleasant sounding speakers.
