Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Restoring two University speakers. Could someone identify these old capacitors with good modern replacements part number? Also, would they be polarity specific? Thanks.
First two are 2uFd, 50V. Third is 120uFd, 50V. Can't tell on the last one. They should be available from Parts Express. All capacitors for crossovers should be bi-polar.
Dayton Audio PMPC-2.0 2.0uF 250V Precision Audio CapacitorDayton Audio is once again leading the charge at bringing high quality, high value products to the speaker building community. Their new line of 1% tolerance capacitors gives you the ability to construct high-precision crossovers, which...
125uF 100V Electrolytic Non-Polarized Crossover CapacitorElectrolytic non-polarized (bi-polar) capacitors are perfect low-cost solutions for use in passive speaker crossovers. These capacitors feature axial leads, a 5% dissipation factor, and are rated at a 100 VDC working voltage which equates...
if there are going into some very good speaker cabs? I'd put in F&T from West Germany caps in them. very good caps. some of the best audio caps available today. find them on the web at Antique Audio and Radio
