Hey Folks,
I have a peculiar condition that I am looking to get some perspective on regarding a Pioneer SX-750 that I just finished restoring with new caps and transistors. After completing the job, I proceeded to do a power test with an 8-ohm dummy load and scope to look for channel symmetry and max watts per channel. During the test, I noticed that both channels were not tracking as closely as I had hoped and that the left/right channels were experiencing some asymmetrical clipping.
Here is the maximum voltage I can squeak out of both channels before clipping. About 55 watts per channel (although sometimes I am unable to reach this wattage). Notice the deviant left and right channel tracking.
Upon further digging, I decided to isolate the pre-amp from the power amp by unhooking the lead wires and scoping the pre-amp only. Again, I found more interesting behavior. The results are below.
Notice the asymmetrical clipping on the negative cycle of both channels.
I am not sure what to think about these results and if they are contributing to the poor tracking in the power amp.
The volume pot and balance knob have been cleaned thoroughly and track perfectly. I have validated this by scoping the voltages directly before the pre-amp section.
Good overlay of both channels before pre-amp:
I initially thought the ICs on the tone board may be a suspect. I checked all passive components surrounding the ICs as well and they all checked out. Any thoughts here? Am I chasing my tail to solve this issue? or is this kind of performance to be expected and I should just move on and enjoy the amp.
Thanks all!
Thanks all!
