.:. Up-Down-Up-Down... Counting
-87
The way this game's evolved, it looks like we'll forever be in the negative integers.
DNU:
There's a reason for that. I've charted the monthly count since inception:
As you can see, in April of '24 we were counting down, as we should have. But I missed the 1st of May turn-around and we continued to count down. Since then the trend has been in the negative numbers.
This March we continue to count down, but maybe this April we can make a concerted effort to bring the count back to positive numbers.
:End DNU
DNU:
As you can see, in April of '24 we were counting down, as we should have. But in May of '24 I missed the turn-around and we continued to count down. Since then the trend has been in the negative numbers.
:End DNU
Huh? There was a turn on 5/24; there is a sawtooth at every month.. I don't understand what you are writing.
I used the count at the end of the month and plotted that. I suppose I could have used the count at the beginning of each month, but I chose the opposite. There's a change of direction every month except from March of 24 to May of 24, which is a straight line downward.
Here's where the turn didn't occur:
120. Month end - direction reverses.
Quotes don't show dates, but if you go to page 144, you can see what I'm quoting. We were counting down in April, and should have been counting up in May, but I kept counting down.
Bad doggie! :rflmao:
I was only referring to your graph- why doesn't it reveal itself on that?
It does, if you look at the March of '24 to May of '24 trend, it's a straight line downward. It doesn't turn around at the end of April/1st of May, which it should have.
