pete_mac
I recently recapped a near-mint AU-217 owned by a friend. He also wanted the push-terminal speaker connections changed to binding posts, as he has a wide variety of speaker cables with spade or banana plugs on them, and sorely wanted to use them with the Sansui.
I bought a small piece of 3mm smoked grey (tinted) perspex/plexiglas and some generic binding posts (he wasn't fussed regarding what I used... so long as it did the job!). All in all, it turned out quite neatly. With the lid fitted on the amp, you can hardly tell that the perspex is partly transparent.
I needed to drill 6 holes to mount the perspex plate, but if he ever wishes to return the amp to standard form, the screws can remain in place and it will generally look OK.
I think I will definitely do the same thing to my AU-517 and other amps in future. I much prefer the flexibility offered by binding posts vs push-terminal connectors.
