The only advantage a specialised power lead could impart is the reduction of AC hum, assuming the power lead is shielded, and if the cord is laying amongst your interconnects. A better and cheaper solution is to arrange the cables at the rear of your system betterm by making sure ICs and speaker leads cross any power lead at 90deg, and do not let them run parallel and close to each other.
Unless you have gone to some piddly baby gauge wire, any normal power lead, including the one that comes with your equipment (be it a separate lead or built in) will deliver the necessary power to run the device. An exotic lead will not give you more volts or amps over a standard power lead.
There is no significant.. or even insignificant.. loss of power when comparing a normal power lead to an exotic one - unless you have a 50foot or longer run between the power point and the amp. The short distance from power point to equipment, on your standard power lead, introduces no loss (well, it may be a millivolt or two, and even if it was a bit more it is still well within the power supply requirements).
Copper in cables is 99.999% oxygen free, so going for that extra .0009% is going to make squat-all difference. This oxygen-free marketing hype is something that sucks in a lot of people.
And, I'm the same as blackfly... if I were very very wealthy I'd buy some exotic power cables, not for any improvement in sound, but for looks and 'cos I can.
