Upgrading an idler wheel?
BHamm
The pendulum swings.
I have several idler wheel turntables and have occasionally seen custom remanufactured idler wheels. That is to say, instead of the stock wheel, the wheel is made of machined aluminum with a sintered bronze bushing and the outer rubber is an o-ring. The theory being that the o-ring provides a much smaller contact area on the motor pulley and inside platter, thereby transferring less rumble and vibration. Sounds reasonable to me, or am I missing something. Has anyone out there used such a wheel, and has an opinion?
BHamm
Replacing an O-Ring to keep round sounds like a good idea to me. This would be more like the design of a cassette deck idler wheel.
Thanks,
Ron-C
I've seen the kind of wheels you refer to, and they look good. I'd have a few questions about 'em, though.
O-rings are used primarily because they are readily available today, whereas rubber in the form of an idler wheel has to be manufactured. Obviously, using something ready-made is much cheaper. It is cost, not performance, that led to this --but that alone does not say that the performance is better or worse than the original design.
A clever DIYer tried an idler wheel, found it worked, and the idea has caught on. As far as I can tell, few if any serious A/B testing experiments have been done to see which might be better.
Is the contact area really that much smaller? O-rings are typically supposed to deform slightly to create seals, and so most commercially-made O-rings are made with much softer rubber than than that used in idler wheels. If there is more deformation at the point of contact of an idler wheel, the actual contact area may be similar to, or even greater, than that of an original idler. Some of the idler-wheels I've found had beveled "knife-edge" contact areas, which, especially in a harder rubber, could form even smaller contact areas than an O-ring. But many of the older idler-wheels have been worn down from years of use, to where they have wider, flatter contact surfaces. Clearly, these could be worse.
That said, the softer rubber of many o-rings may wear over time in a similar fashion. You might well end up having to replace the o-rings more often than you'd have needed to replace a harder-rubber idler wheel. But o-rings are cheap and easily replaced, so this shouldn't be a big problem; it's on a par with replacing belts.
I have seen some with THREE O-rings being used: two side-by-side to form a base, and one between and atop them, which actually makes contact with the platter. Such a design would do more to isolate vibration, but it might also introduce a wee bit more speed instability(?)... but any such instability would still be much less than that from a belt, and could probably be entirely discounted.
Better (more precisely made and smoother) bearings should, indeed, be an improvement, allowing for less bearing noise, less bearing-induced vibration or instability, etc...
The materials from which the wheel itself is made (types of plastic or metal) of course will affect the manner in which vibrations pass through it. In an idler wheel, one ideally wants something entirely rigid, but which stops all vibration from being transmitted through it. No material does that perfectly. Something like DuPont's Delrin might be superior at this, but metal is a more practical alternative. Using two metals in the construction (with the addition of bronze for the bushing/bearing sleeve) might tend to lower the transmission of vibration, in comparison with using a single, solid metal, but the exact effects depend upon the specific materials and which frequencies one is considering.
In practical application, people using these "newfangled" idler wheels seem quite happy with them, and I see no major problems (and some advantages) with them, so I'd say go ahead and try one. They won't be bad, in any case, and at least in some ways (better bearings) should be better. Plus you'll get the convenience of easily-changed O-ring construction. But whether they are fundamentally better than the original-type designs remains to be proven, I think.
All good points Arkay,
I used an O-ring replacement on a channeled plastic Lenco idler wheel. It really was a stop-gap until I could get a proper rebuild (ironically, using a different O-ring that was melded to the wheel and then honed and shaped to match the profile.)
This however, was for that special to Lenco under platter-tracking and may not apply to Bhamm's case which seems to be motor spindle-to-rim tracking.
Still the O-ring was serviceable for awhile even though I'm sure it wasn't as accurate as the honed profile of the original tire.
- Mario
I'm interested in this because the hole in my B12 idler wheel (the original ROK one, rebuilt within the last year) isn't perfectly straight, and as a result, it "rocks" a little as it spins on the shaft. It's actually the noisiest part of the drive, and I've thought more than once about seeking out another one. Does anyone know a source for some of these "remanufactured" idler wheels to which BHamm alludes?
I found the wheel for which I speak on ebay. It's about the same price as having the stock wheel rebuilt. It looks very well made.
Arkay brought up good points to consider. Also, o-rings come in many different thicknesses for any given diameter.
Any good machinist could replicate an idler wheel using whatever thickness o-ring you choose, but the smaller the contact patch an o-ring makes, the less grip it will have for spinning the platter.
I think I will give it a spin--literally.
Great! I may do the same (if I can find one). Thanks for raising the question.
O-rings are available in harder rubber. A 90 durometer (shore "A" scale) is actually fairly hard and could handle the idler wheel duty pretty easily. Most hardware store and home centers carry 70 durometer o-rings. The 90 durometer rings (designed to handle more pressure) are available from industrial supply catalogs and websites such as Grainger.
These are fairly common on the old time RCA 45 players. The original double idlers tend to get pricey, and need rebuilds. They don't age well, so this works.
